Need help - broke solenoid while uninstalling CAI
I broke the air solenoid (the thing you relocate when installing a cold air intake). Is this going to cause problems? I started my engine and everything seems fine (no check engine light). Is it okay if I drive around like this?
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
If you are talking about that big tank thing (big plastic square) I think that is called the Vacuum tank. It cost me like $15 bucks to get a new one and install it. If you broke the little metal peice that is the sensor (screws on to the plastic tank) those are like $130.
I needed a temp solution when I broke my vacuum tank (installing CAI) so I just dremeled it down and superglued the hose in place. It seemed to work find for the two weeks it took to get the part.
Originally posted by AlgaeHater
I broke one of the nipples that the hose attaches to.
