Need help...best way to remove gum from carpet?
Spot Shot or Griots Garage interior cleaner. 3M adhesive remover works too but may take the color out of the carpet, as will some of the citrus cleaners, and Goof Off.
Lacquer thinner works fine, remember to test for colorfastness first. Also remember if there is any adhesive sticking the carpet to the surface behind it (not likely in a car) it will loosen this too. This is the "standard" method I've always used when I used to work in a retail audio store.
Originally posted by rocketman
I have heard somewhere before to use ice to get the gum brittle and hard, then pull or brush out.
