Need Help~~~
Old 03-02-2005 | 02:41 PM
S2K4eva's Avatar
Default Need Help~~~
I would like to change headlight diffusers. I have started working out.
At first, I took off my bumper cover.
Second, I also took off my headlight.
After the second job, what am I gonna do next?
I only know how to bake those headlights ...so do i have to take off the hid blast and burbs?
I already read the installation on rick's s2k wesite, but i don't exactly understand it.
I want to make sure every steps going perfectly.
Could you give me installation tips and notes for me that i might have mistake duing the job?
Old 03-02-2005 | 03:05 PM
efthimios's Avatar
this is no flame, but if you didn't understand the directions don't you think you should've figured this out prior to? doesnt' matter......his directions were very clear to me...you should just send them to w1ngman and have them "professionally" done. He only charges $100 and you won't have to worry about anything
Old 03-02-2005 | 06:01 PM
TwistedS2k's Avatar
I thought the directions were pretty clear. If you don't understand then don't do it yourself. Let someone else do it for you. Otherwise you will f.ck it up
Old 03-02-2005 | 08:26 PM
S2K4eva's Avatar
im trying to make them separately
but its really really hard now
is that fine to bake the light with hid burb??
Old 03-02-2005 | 10:07 PM
fhyun's Avatar
You can place the headlights with the HID ballast in the oven, but make sure you don't put them in too long. It might take multiple bakes to loosen the silicon sealant. The housing does not come off that easily. Also, here is a link that helped me with the installation.
https://www.s2ki.com/forums/index.ph...opic=50775&hl=
good luck!
mrxwormxsayz
01-17-2009 04:57 AM
S2K4eva
03-03-2005 01:12 AM
03s2kman
08-25-2003 07:32 PM
03s2kman
07-27-2003 08:08 AM
silverpdxs2k
46
04-11-2002 08:42 AM
Quick Reply: Need Help~~~
