my02 prewired for rear speakers?
Jeff,
Did you install Lucid rear panel or cut out openings yourself? What size speakers did you go with? I'm thinking about doing to obtain more bass.
Jeff Sfetko
______________
2002 Red Rush #2234
2003 G35 Garnet Red
1997 Ranger
Jeff Sfetko
______________
2002 Red Rush #2234
2003 G35 Garnet Red
1997 Ranger
Originally posted by GChambers
You Rock! Thanks for the pic. I always keep the seat back as far as it will go. I wonder if the seat would block any sound that comes out of the speaker.
Speaker wires must be added. Lucid sell's all the wiring, But I made my own. I used 5 1/4 Blaupunkt speakers and cut the panels myself. I did not use Lucid's harness, because I have access to honda pin terminals. I simply ran 4 speaker wires under the console cover and added factory pins in the exsisting radio connector. Same effect as Lucid's harness, just easier/cheaper for me. The connector is only on 02's and up. It's for the hardtop defroster harness. Plastic window cars have completely different defroster wiring for the hardtop.
i am going to wire my own speakers and cut my own panels.
but i am still don't know how and where shell i run my wires? any diagram or pic will be helpful too.
and what kind of wires? where to get? i am running aftermarket HU but not external amp.
i got some wires from home depot, can i use them?
Sorry, no pics. I used 14 Gauge automotive stranded wire. The speaker wire can be run directly under the console cover back to the rear panels. I Unless you can convince a Honda dealer to sell you the correct pins, (BIG pain) Don't try it like I did. Lucid's harness really is the easy way to go. You just plug everything in. I used a 2001 Accord ETM to determine the correct pins in the radio connector. You need a very specific wiring pin to properly lock into the connector. I doubt a dealer's parts dept. would be able to find the right one without a major hassle. Your other option is to run 4 speaker wires to the HU itself bypassing the stock connector. Since I have a stock radio, I can't do this.
