MY01, Door lock cylinder removal
Hello guys, trying to remove the door lock cylinder today, but i cant figure out how, seems like i cant understand what the manual say
so, could u guys give me some advices?
Image:
http://yfrog.com/n804092009048j
Thank you
Image:
Thank you
There is a "C" clip holding that in place on the bottom. So you a pair of needle nose pliers to pull it down to remove the C clip. Then you can remove the hardware holding the handle in place and with it the cylinder.
Hello, thanks for reply
I have already removed one "C" clip that holding the cylinder switch and rod together, im not sure if that is the one you mentioned, so there is another one i need to take off
Thanks!!
Thanks!!
