my s2k brake problemmmm
well my 2005 s2k i have stock brakes , brake pads ebs and ventus tires i feel i am loosing braking power or doesnt break has much has my previous serie 3 bmw , maybe are the ventus tires or that i also need to change my brake fluid...
my question is can i use blue racing brake liquid....
or maybe some brake lines and r compound can improve my braking...
Besides Brake Pads, you will find that Tires will affect your braking distance the most. Be sure to check your Brake Fluid Level, as if it is low, your Braking Performance will suffer.
I have found that the best combination for braking is as follows:
1. Sticky Tires (Star Specs, RE01R, etc.)
2. Fluid (ATE Super Blue, Motul, etc.)
3. Brake Pads (Do Not Cheap Out On These) (Project Mu, Carbotech, etc.)
If you feel compelled to, you can also get Stainless Braided Brake Lines. These will improve the feel when braking as they don't give to expansion the way the stock lines do.
I was always under the impression that the s2k does in fact have braided brake lines. The braid is just covered by outside coat of rubber. Can anyone shed some light on this?
Terror hit the nail on the head with his first reply though. Do what he says and you will be stopping on a dime.
