Mugen 2.2L Header
Old 10-26-2006, 08:05 AM
Vitt's Avatar
Originally Posted by MugenRioS2k,Oct 26 2006, 07:32 AM
I think I am the first person to actually post dyno plots for the Mugen 2.2L header gains
First one I've seen other than the King website.
good info, thank you.
Old 10-26-2006, 08:57 AM
SaltyDog's Avatar
I'm awaiting my Mugen 2.2 header now. It will be teamed with an AP2 Mugen Dual and Comptech supercharged.
Old 10-26-2006, 09:17 AM
MugenRioS2k's Avatar
are you going to be installing it all at the same time.
I would love to see what gains can be made by the AP2 Mugen dual exhaust.
Complaining which cat back to go with now that the header is done.
Old 10-26-2006, 09:50 AM
Red_Devil's Avatar
Cool! Thanks for sharing your info!
Old 10-26-2006, 10:15 AM
Rdrcr's Avatar
MugenRioS2k, thank you!
Looks like there was still a decent gain even before the fuel adjustment.
I am contemplating the Mugen 2.2 header, Toda Racing exhaust (if I can ever see some pictures of the exhaust installed on a S), and the Hondata re-flash.
Mike
Old 10-26-2006, 10:43 AM
Even though the graphs do not show it but dyno sais there is more power added when moving forward then what was shown on the dyno.
I have theSpoon scoop and do get a bit of +pressure in the manifold above 70mph (+.08psi).
While not much its still is + pressure
Old 10-26-2006, 03:45 PM
SaltyDog's Avatar
The supercharger is currently installed but has yet to be "properly" tuned. A full tune of the car will be done at completion of the project. The supercharger is also aftercooled as well. The Mugen header and exhaust will be installed at the same time. The stock cat will also be left to help aid in torque.
Old 10-26-2006, 04:59 PM
remove the cat and run a test pipe that has a dim that is as close to the Mugen exhaust/header as possible
Megan 60mm
or the T1R 63mm
my vot woud be for the T1R
(O2 CEL mod and cat heat shield can be reinstalled to retain cat look)
Old 10-26-2006, 05:38 PM
tcjensen's Avatar
backpressure doesn't equal torque; exhaust velocity does
While we are on this topic, my future plans include a mugen 2.2 header: is the collector diameter 60-60.5mm like stock? Thanks
Old 10-26-2006, 05:50 PM
Stock collector ID is 54mm just measured it
Mugen 2.2L header collector is larger should have measured it; I would assume it is 60.5mm ID just like the Mugen +04 exhaust. I will measure it when I take the header off to wrap it and install a test pipe (63mm T1R)
Explanation of back pressure:
Back pressure is bad in all since when it comes to extracting power form an engine.
However there is an inversely proportional relationship between induced backpressure due to pipe diameters and exhaust velocity.
Exhaust velocity is what you are looking for when trying to maximize exhaust gas scavenging.
However to get an increase in exhaust velocity (with a fixed amount of mass flow) one must decrease the pipe diameter to get more speed (ignoring the effects of increases mass density due to gas cooling as it travels down the pipe) mass flow in must = mass flow out
JF81
02-09-2008 03:31 PM
NFRS2kSi
Member S2000 Classifieds and For Sale
05-10-2006 07:10 AM
HvRRZ
03-15-2006 06:52 PM
f20c1 01s2k
05-31-2005 12:23 PM
jdmwhiteboy
08-10-2002 06:53 PM
Quick Reply: Mugen 2.2L Header
