mobile 1
I run Dino oil, why?
S2ks burn oil and synthetic burns alot easier then non-synthetic (makes for less gunk build-up if your burning less oil).
I religiously change my oil every 2500-3000 miles.
The only advantage you can get out of synthetic oil is its heat tolernace/extended life. On this note I can see synthetic being a better option for a turbocharged s2k.
In the end my oil is half the cost, barely gets 'burned-up' by the engine, and works just as good in my near-stock engine.
If I were to run synthetic I would atleast go with a fluid better then mobil1.
