maintenance light
Originally Posted by bigmac834,Oct 11 2007, 04:19 PM
By the way, has anyone heard of "Safeguard Lease". It's like $600.
It is an insurance policy on the wear and tear during the lease. Basically anything that Honda says is excessive wear and tear they will charge the lease holder. BUT, this covers all that up to $5,000.00.
Originally Posted by YoZUpZ,Oct 12 2007, 05:49 PM
Tire rotation? umm... staggered setup, and you are NEVER supposed to switch tires from one side of the vehicle to the other...
You want to show proof where you can't do that?
Originally Posted by mxt_77,Oct 12 2007, 07:56 PM
That only goes for directional tires (which I'd guess most people use on the S2000). If you swap them to the other side, then they'll be rotating the "wrong" way. However, you could theoretically pull the tires off the wheel and swap it onto the other side, but I guarantee you that Honda didn't do that.
Originally Posted by nightcrawler7188,Oct 12 2007, 03:04 PM
note to the original poster: do not take your car to honda unless you suspect you need to get it checked for a TSB.
Originally Posted by nightcrawler7188,Oct 15 2007, 07:52 PM
maybe you didn't properly click the shifter into reverse and that caused a problem??
Originally Posted by bigmac834,Oct 15 2007, 09:41 PM
Well I think I need to bring it to Honda again... (this is going to be hard to explain)I turned my car on, put it in reverse and put the handbrake down, when I started to back up it felt like something blew off??? Then i gave extra gas and it finally started going. Then I put it in 1st and bgan to go, but it would grab onto 1st. So I put it back in nuetral and tryed again and it worked. WHATS WRONG?
