Maint Req'd and CEL
Maint Req'd and CEL
Last night i was driving to Athens which is about a hour drive. I was doing some spirited driving. I got a Maint Req'D light flash for about 30-40seconds then dissapear. At the time it happened i was just cruising at 4-5k.
Is this anything to worry about? It hasn't come back since, but i'm just cautions. Also is the Maint' Reqd light the same a CEL(check engine light).
Also, where is the odb-2 connector, i have a reader so i can check codes/clear them.
Thanks!
Thanks!
maintenance req'd is different than a CEL. MR light is saying to you need a oil change....it comes on every 5-7500 miles. just reset and your set....go to the FAQ's in Under the hood and you'll find what you need
