lug nut size (mm)
Old 03-15-2005 | 08:00 AM
S2kracka's Avatar
Default lug nut size (mm)
I'm going to buy a new socket for my torque wrench and just need to know what size the factory lug nuts are. Thanks in advance.
gomarlins3's Avatar
19 I believe. Everything I have found on the net states the size of the lugs as 12mm X 1.5, but I believe that is the diameter and length. The circumference (what your socket will be) I still think is 19mm. If I was home i could tell you for sure because it's the size I leave on the impact wrench.
Old 03-15-2005 | 08:09 AM
koala's Avatar
19mm
Old 03-15-2005 | 08:16 AM
S2kracka's Avatar
Thanks to both of you.
Old 03-15-2005 | 08:18 AM
gomarlins3's Avatar
This is the set I use:
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=40962
02widowmaker
05-29-2011 12:35 AM
Zomax
11-05-2008 06:55 PM
hyperion_
07-12-2006 10:24 AM
gochuxsaurus
09-07-2005 10:19 PM
Tanqueray
03-04-2002 08:40 AM
Quick Reply: lug nut size (mm)
