lowering springs
#21
Here's some research I did that may help if you're interested in spring rates.
https://www.s2ki.com/forums/index.php?showt...0&#entry4314045
#22
Originally Posted by stingerbtry,Oct 27 2004, 11:09 PM
I think that's too much tire for 18's. I run 17" ASA FR1's with Front--17x8 +58 w/ Bridgestone Potenza S03 225/45-17 and Rear--17x9 +62 w/ Bridgestone Potenza S03 255/40-17 on s-tech's and they fit perfectly. I think the 40's in the rear for 18's would rub and also throw off your speedo. I believe you should run 35's in the rear, someone correct me if I'm wrong.
#23
Originally Posted by topcat7111,Oct 28 2004, 04:36 AM
I have these Stech springs....they're on the soft side(compare to kg/mm race), just a little stiffer than the stock springs. I'm running Work S1 18x8 +56 front with 225/40-18 and 18x9.5 +62 with 255/35-18 Yoko ES100 and i have no rubbing issue. Be sure to get an alignment cause your camber and toe will be out of spec.
good sutff guys
SOLE2K
San Diego S2000 Owners
20
10-11-2007 03:30 PM
