Lower Springs
you can get neuspeed springs, those drop it the most i believe and that is like 1.75. Dropping the s2k lower than 1 inch hurts your suspension, cornering wise. This is what I have gotten from the forum.
If you want a good set up, you should get kg/mm race springs with koni yellows or a set of gound control w/ koni yellows. With the ground control you can go pretty low since it will be adjustable.
