List of Reall Notices and TSBs
Old 06-24-2002 | 03:20 PM
pdippell's Avatar
Default List of Reall Notices and TSBs
Just found this list at www.alldata.com, purports to be comprehensive, fyi:
Model Year 2000
Bulletins for 2000 Honda S2000 L4-1997cc 2.0L DOHC (VTEC) MFI
Safety Recalls
TSB Number Issue Date TSB Title 00-020 FEB 00 Recall - Convertable Top Cover
Service Bulletins
TSB Number Issue Date TSB Title 00-088 AUG 01 Brake Discs - Refinishing Guidelines
98-011 AUG 01 Keyless Entry - Transmitter
01-038 MAR 01 Convertible Top Cover - Comes Loose
01-008 JAN 01 Driver's Window - Will Not Go All The Way Down
00-054 DEC 00 Engine/Transmission - Buzzing on Deceleration
00-099 DEC 00 Wiring Terminal - Repair Instructions
00-088 NOV 00 Brake Rotor - Refinishing Guidelines
00-083 OCT 00 Heater Unit - Water Drips Onto Passenger's Carpet
00-089 OCT 00 Supplemental Restraint System - Inspection
00-048 SEP 00 Convertible Top Rear Window Replacement - Manual Update
00-055 SEP 00 M/T - Grinding When Shifting Into 2nd Gear
00-063 AUG 00 Special Tool - Chassis EAR™, Diagnostic Tool
00-057 JUL 00 CD Player - Sound Cuts Out at High Volume
00-049 JUL 00 Immobilizer System - Type 2: Operation/Part Replacement
99-053 JUN 00 Immobilizer Key - Key Code Duplicator
00-050 JUN 00 Accessory Floor Mat - Anchor Moves From Side to Side
99-018 APR 00 Required Special Tools And Equipment,
00-037 APR 00 Convertable Top Rear Window - Creased, Cloudy, Scratched
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-015 MAR 00 Audio Unit with CD Player/Changer - Error Codes
00-032 MAR 00 Paint Codes
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
97-015 DEC 99 Service Publications - Availability & Ordering
98-031 NOV 99 Aftermarket On Board Diagnostic (OBD) || Tester
99-062 OCT 99 Paint Damage From Environmental Fallout
97-015 AUG 99 97-015 - 08/31/1999
99-030 MAY 99 Recommended Materials
98-051 AUG 98 Special Tool Loan Program
Model Year 2001
Model Year 2002
Old 06-24-2002 | 05:13 PM
kingkong's Avatar
What's the refinishing guidelines for the brake rotors about? Does this fix the rust?
Old 06-24-2002 | 05:19 PM
pellisS2k's Avatar
I'm a little concerned about
Old 06-24-2002 | 05:57 PM
RedHead's Avatar
Me too. Where can I find that torque converter thingie on the S2000?
Old 06-26-2002 | 06:21 AM
speedlife's Avatar
[QUOTE]Originally posted by pdippell
[B]Just found this list at www.alldata.com, purports to be comprehensive, fyi:
Model Year 2000
Safety Recalls
Old 06-29-2002 | 04:18 AM
landefam's Avatar
I'm also concerned about the TSP for '02 MY.
Do you have more information about the TSB? Can
you post a copy of it?
Thanks.
Old 07-04-2002 | 07:26 PM
dlq04's Avatar
Here's more for those who like to worry --
TECHNICAL SERVICE BULLETINS
(http://www.nhtsa.org/)
Search for records on
Year: 2000
Make: HONDA
Model: S2000
Make: HONDA Model: S2000 Year: 2000
Service Bulletin Number: 000101 Bulletin Sequence Number: 103 Date of Bulletin: 01/00
NHTSA Item Number: SB610337
Component: INTERIOR SYSTEMS:SEAT AND SHOULDER BELTS AND BELT ANCHOR:OTHER PARTS
Summary:
INFORMATION ON REPLACING THE SEAT BELT TENSIONERS. *TT
Service Bulletin Number: 00037 Bulletin Sequence Number: 125 Date of Bulletin: 04/00
NHTSA Item Number: SB612554
Component: VISUAL SYSTEMS
Summary:
VEHICLES MAY EXPERIENCED THE REAR WINDOW THAT IS CREASED, CLOUDED, OR SCRATCHED. *MJS
Service Bulletin Number: 00054 Bulletin Sequence Number: 156 Date of Bulletin: 12/00
NHTSA Item Number: SB615716
Component: POWER TRAIN:TRANSMISSION:UNKNOWN TYPE
Summary:
WHILE DECELERATING IN 3RD OR 2ND GEAR, A BUZZING OR RATTLING COMES FROM THE ENGINE OR TRANSMISSION BETWEEN 4,000 AND 3,000 RPM. *TT
Service Bulletin Number: 00054 Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: SB619919
Summary:
EXPERIENCING A BUZZ OR RATTLE FROM THE ENGINE OR TRANSMISSION WHILE DECELERATING. *TT ---------------------------------------------
Service Bulletin Number: 00078 Bulletin Sequence Number: 189 Date of Bulletin: 10/00
NHTSA Item Number: SB618934
Component: INTERIOR SYSTEMS:ACTIVE RESTRAINTS:BELT RETRACTORS
Summary:
PRELIMINARY SERVICE BULLETIN REGARDING SAFETY RECALL - S2000 SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 00083 Bulletin Sequence Number: 199 Date of Bulletin: 10/00
NHTSA Item Number: SB619954
Component: AIR CONDITIONER
Summary:
THIS BULLETIN STATES THAT IN HUMID CONDITIONS, WITH THE A/C ON AND THE FAN RUNNING AT MAXIMUM SPEED, WATER DRIPS ON THE PASSENGER'S CARPET. *TT
Service Bulletin Number: 010200 Bulletin Sequence Number: 189 Date of Bulletin: 02/00
NHTSA Item Number: SB618951
Component: ENGINE COOLING SYSTEM:OTHER PARTS
Summary:
BRIEF INFORMATION ON DIAGNOSING ENGINE COOLANT TEMPERATURE SENSORS AND TEMPERATURE GAUGES. *TT
NHTSA Item Number: SB618955
Component: ENGINE
Summary:
INFORMATION ON THE S2000 ENGINE AND OIL CONSUMPTION. *TT
NHTSA Item Number: SB618958
Component: ENGINE
Summary:
INFORMATION ON HONING FIBER REINFORCED METAL (FRM) CYLINDERS. *TT
NHTSA Item Number: SB618959
Component: POWER TRAIN:TRANSMISSION:AUTOMATIC:CONTROL MODULE (TCM, PCM)
Summary:
BRIEF INFORMATION USED WHEN ORDERING PARTS FOR SERVICE BULLETIN 00-055 - GRINDS WHEN SHIFTING INTO 2ND GEAR. *TT
Service Bulletin Number: 01038 Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: SB619927
Component: STRUCTURE:BODY ROOF:CONVERTIBLE TOP
Summary:
ON CERTAIN VEHICLES, THE REAR PART OF THE CONVERTIBLE TOP COVER DOES NOT STAY TUCKED IN. *TT ---------------------------------------------------------------
Service Bulletin Number: 010400 Bulletin Sequence Number: 189 Date of Bulletin: 04/00
NHTSA Item Number: SB618982
Component: AIR CONDITIONER:COMPRESSOR
Summary:
SUBJECT REGARDING A/C COMPRESSOR MOUNTING BOLT TORQUE. *TT
NHTSA Item Number: SB618992
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary:
INFORMATION ON RESETTING THE MAINTENANCE REQUIRED INDICATOR. *TT
NHTSA Item Number: SB618997
Component: MANUFACTURERS INFORMATION TO DEALERS
Summary:
INFORMATION ON THE SERVICE MANUAL INDEX. *TT
Service Bulletin Number: 010999 Bulletin Sequence Number: 800 Date of Bulletin: 09/99
NHTSA Item Number: SB608007
Summary:
INFORMATION ON NEW S2000 ROADSTER. *TT
Service Bulletin Number: 011000 Bulletin Sequence Number: 189 Date of Bulletin: 10/00
NHTSA Item Number: SB618933
Summary:
LETTER TO SERVICE MANAGER REGARDING SAFETY RECALL 00-078 - S2000 SEAT BELT RETRACTORS. *TT
NHTSA Item Number: SB618968
Summary:
INFORMATION ON REPLACING VINYL REAR WINDOW. *TT
Service Bulletin Number: 031000 Bulletin Sequence Number: 189 Date of Bulletin: 10/00
NHTSA Item Number: SB618929
Summary:
SUBJECT REGARDING RECALL ANNOUNCEMENT AND STOP SALE ORDER FOR 2000 MODEL YEAR VEHICLES EXHIBITING THE SEAT BELT RETRACTOR THAT MAY OCCASIONALLY LOCK UP WITH THE BELT FULLY RETRACTED. *TT
Make: HONDA Model: S2000 Year: 2000 Service Bulletin Number: 171100 Bulletin Sequence Number: 157 Date of Bulletin: 11/00
NHTSA Item Number: SB615764
Summary:
INFORMATION REGARDING MISPACKAGED SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 181000 Bulletin Sequence Number: 188 Date of Bulletin: 10/00
NHTSA Item Number: SB618917
Summary:
SUBJECT REGARDING SEAT BELT RETRACTOR RECALL UPDATE. *TT
TECHNICAL SERVICE BULLETINS - Another Source
http://www.alldata.com/TSB/24/002446AF.html
Safety Recalls
. 00-020 FEB 00 Recall - Convertable Top Cover
Service Bulletins
. 01-008 JAN 01 Driver's Window - Will Not Go All The Way Down
. 00-054 DEC 00 Engine/Transmission - Buzzing on Deceleration
. 00-099 DEC 00 Wiring Terminal - Repair Instructions
. 00-088 NOV 00 Brake Rotor - Refinishing Guidelines
. 00-083 OCT 00 Heater Unit - Water Drips Onto Passenger's Carpet
. 00-089 OCT 00 Supplemental Restraint System - Inspection
. 00-048 SEP 00 Convertible Top Rear Window Replacement - Manual Update
. 00-055 SEP 00 M/T - Grinding When Shifting Into 2nd Gear
. 00-063 AUG 00 Special Tool - Chassis EAR™, Diagnostic Tool
. 00-057 JUL 00 CD Player - Sound Cuts Out at High Volume
. 00-049 JUL 00 Immobilizer System - Type 2: Operation/Part Replacement
. 00-050 JUN 00 Accessory Floor Mat - Anchor Moves From Side to Side
. 99-078 APR 00 Pre-delivery Inspection and New Model Information
. 99-018 APR 00 Required Special Tools And Equipment,
. 00-043 APR 00 Rear Window Wiper Motor - Radio Static
. 00-037 APR 00 Convertable Top Rear Window - Creased, Cloudy, Scratched
. 98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
. 00-015 MAR 00 Audio Unit with CD Player/Changer - Error Codes
. 00-032 MAR 00 Paint Codes
. 00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
. 97-015 DEC 99 Service Publications - Availability & Ordering
. 98-031 NOV 99 Aftermarket On Board Diagnostic (OBD) || Tester
. 99-062 OCT 99 Paint Damage From Environmental Fallout
. 99-053 OCT 99 Antitheft System - Key Code Duplicator
. 97-015 AUG 99 97-015 - 08/31/1999
. 99-030 MAY 99 Recommended Materials
. 98-051 AUG 98 Special Tool Loan Program
tekstar
04-01-2007 02:03 PM
OC S2K
09-24-2003 01:12 PM
import-depot.com
07-24-2002 08:03 PM
Rdriver
07-17-2002 12:14 PM
bayareas2k1
11-04-2001 06:12 PM
Quick Reply: List of Reall Notices and TSBs
