View Poll Results: Which one??
Voters: 9. You may not vote on this poll
Invidia V3 Dual OR Greddy Ti-C Dual ?
Ok I had my heart sset on the Invidia V3 Dual Exhaust but now see that Greddy makes a similar version....the y pipe is not symmetrical like the Invidia but it's still very attractive....am I looking at the same 3-5 hp gain with this Greddy System?? I want a nice sounding exhaust and quite frankly the Invidia will make it sound like an F1 car at WOT.....which exhaust has the better quality?? which one should I go with??
I would honestly go for the T1R 70 Sparrow. T1R makes good products and their service is great. And of course the sound is amazing.
Check it out... there's a sound clip in there too at the bottom of the post.
https://www.s2ki.com/forums/index.php?showtopic=474176
Andre
Andre
A little pricier however....and i'm pretty sure the weigh savings will be the same with the Invidia and Greddy...roughly 25-30lbs....and Invidia claims about the same gain as the T1R...
I'd go Invidia as it's much cheaper, same look, same diameter, etc.
Originally Posted by GOS2K007,Jun 14 2007, 07:06 AM
Yes, the T1R is pricier and from the research I've done talking to people that have owned both T1R and Invidia the T1R is louder than the Invidia which I find to be crazy.
Andre
Originally Posted by 8kGoodENuff,Jun 14 2007, 11:50 AM
Really?... I hear that everyone complains about how loud the Invidia is. I met someone at the track not too long ago with the invidia and it was loud. I don't know then... it all depends on which you like I suppose.
Andre
Andre
I have heard the T1R 63mm Sparrow sounds butter with no drone.
Originally Posted by midnightmethane,Jun 14 2007, 12:12 PM
I'm NA and still going w/70mm piping...that's still fine isn't it??
the only difference in the T1R 70 and 63 is the pipe from the cat the the Y section is 70mm. The piping to the canisters is 63mm on both.
I'd run a test pipe with it to see the best gains.
I like the Invidia better cause if you look at the weld. It look alot better then the greddy weld and invidia is fully polished stainless. If you get the test pipe to you get 10 whp.
