Installing Ebach prokit
#21
Originally Posted by mecracer,Sep 29 2006, 01:18 AM
im still trying to figure out whats wrong with my front springs i dont know where to take my car out here in santa clarita so i donno wha to do really.
If you're sure that the springs were installed in the right locations, then I suspect the suspension wasn't loaded before things were tightened back down. Have you posted in your regional forum to see if anyone can recommend a good shop?
#22
Originally Posted by LuDawg,Sep 29 2006, 12:52 PM
It handles ok with them reversed. The enoying part is that I get flashed all the time because people think I have my high beams on. Since the back was lower then the front the light beam was hitting oncoming traffic at eye level. I'm going to call the shop and set up an appointment for next week.
#23
I got my car back from the shop. It handles like a dream! I had them alighn it as well (On the house of couse). The difference is like night and day. Thanks everyone for the help!
#24
i wish mine was that easy. The shop says that my front springs are out about an inch. and they said he might be able to get it in withought taking everything off but im still going to have to pay alot and do alignment agin witch sux i hope it works
#25
#26
Some alignment shops will have trouble with the first alignment after a drop, but once a competent alignment man gets the car right, subsequent alignments will be easy enough for any alignment-rack-jock to handle. If your shop is having trouble getting the car aligned properly I'd suggest trying another shop. If you can find someone who does race cars they'll have no trouble with your S2000.
#27
well alignment wasnt the problem. the problem was that after i lowered the car the front looked like it stayed the same or even got higher so i took it to another shop and the checked it out and said that the spring isnt in properly and that they will need to adjust it and that is what is probable keeping my car at stock hieght. After this is fixed ill try and find someone to do alignment.
#28
Aligning the car isn't that hard, but there is some interaction between the adjustments, and some alignment guys won't take the time it takes to get it right, especially after the car has been lowered. Hopefully you won't have too much trouble finding a good shop. Be sure to ask then if they know how to get a lowered car on their alignment rack without banging it up.
#30
darin nishimura...
west end alignment
(310) 808-9233
gardena i think
07RioS2k
10-27-2008 09:45 AM
