Install Help on Thermostat
If you haven't done it already, it's easy. I just did the install today. It took a little longer because I installed a front grill and had to go out and buy a 24mm hex wrench for the thermoswitch. Once you identify the bolts, it's a piece of cake. You don't need a wobble wrench if you have small hands. I had a short wrench and a 3" extension and could reach both bolts. Like everyone says, jack up the car, get the bottom bolt from the front of the engine mount and the top bolt from the behind of the engine mount.
The pics at www.s2000.org helped me identify the correct bolts. Thanks marcucci
BTW, if you plan to install the thermoswitch, save yourself some time and buy a deep 24mm hex socket before you start. I spent one hour driving around trying to find one of those
