How to remove only radio door?
Old 02-28-2009, 08:47 PM
Artric's Avatar
Default How to remove only radio door?
Although my car is pretty clean, somehow there's some random gunk in the crevices on the backside of the radio door.
On that note, are those crevices there for a reason? What gives?
Anyhow, how do I take just the radio door off so I can get all of that stuff out?
I also might change to the CR one. Do you guys think it'd look OK not changing to any other CR trim?
Old 02-28-2009, 08:57 PM
SupeR_DavE's Avatar
I just changed mine to the CR door,there are two pins one on each hinge,what I did is got a small screwdriver(like eyeglass ones)and push those pins out and door will come off,but be careful and watch the spring(make sure it dont fly away)and reverse it with the new door
Old 02-28-2009, 09:09 PM
dparm's Avatar
You have to remove that whole piece that has the two vents on it. It takes all of 30 seconds.
Old 03-01-2009, 05:39 AM
Artric's Avatar
How? Just pry at it? Is it affixed by clips? The last thing that I want are pry marks in my car, so I want to avoid as much unnecessary stuff as possible!
Old 03-01-2009, 05:54 AM
negcamber's Avatar
https://www.s2ki.com/forums/index.php?showtopic=251894
Note the post by Freq:
With a MY'04+ console the console needs to be removed (or at least pulled up) first before the radio door assembly can be removed. FYI
Old 03-01-2009, 12:00 PM
Enthralled's Avatar
just pull on it homie!! it'll come right out.
Old 03-01-2009, 03:09 PM
Artric's Avatar
Yeeaaaaahhh... no.
Not into pulling on shit until it maybe comes out or maybe breaks.
Thanks for the info everyone!
Old 03-02-2009, 11:56 AM
SheDrivesIt's Avatar
Your MY 04 does NOT just pull right out. The bottom lip of that vent assembly is behind the top section of the center console. You want to unclip that top section, pull it up and then back a bit onto the shifter. Then you can pull out the vent assembly.
Old 03-02-2009, 04:38 PM
Former Sponsor
Moddiction's Avatar
Just gotta work it out. Feels like it might break but pulls right out with some convincing.
Old 03-02-2009, 05:52 PM
Artric's Avatar
Nope, like SheDrivesIt says, you've gotta remove part of the center console. I just saw it in a thread. Should have kept the link to put it here.
Al_G
02-23-2019 05:13 AM
eddie777
12-06-2015 11:38 AM
240toS2k
09-13-2010 08:23 AM
UsmcSway
12-13-2009 01:47 PM
geoffrey06
02-05-2009 03:12 PM
Quick Reply: How to remove only radio door?
