How often do you change your oil?
Old 02-18-2009, 03:48 PM
RL428's Avatar
Default How often do you change your oil?
I change my Mobil1 every 3k miles, it comes out perfectly clean... I've also noticed a lot of people here changing it every 6k, am I throwing money away here? I'm doing this to be safe but I could always use the savings, the oil looks like new when it drains out.
Old 02-18-2009, 03:53 PM
rotorman7's Avatar
i change mine every 2500 to 3000 only cause i owned a rotary before and its just habit.
BTW as soon as you start a rotary after an oil change it goes black
Old 02-18-2009, 03:55 PM
114_ap2's Avatar
depending on how u drive, yes u are wasting your money, but i really shouldn't be talking cause i do the same and i change mines every 3k or 3 months and i use Total (Elf).
Old 02-18-2009, 03:58 PM
JoeS0Fly's Avatar
i try to change mine every 3000, last change was 5000.
didn't have time to change it myself, didn't even have time to drop it off at shop.
and yes, rotary loves to burn oil lol.
Old 02-18-2009, 04:05 PM
cougar hunter's Avatar
I plan on changing mine in 150 more miles (30,000), and I last changed it 5000 miles ago (25,000)
Old 02-18-2009, 04:06 PM
Diego1107's Avatar
Don't high performance engines that use synthetic get changed every 10-15k miles? If not, please correct me immediately haha
Old 02-18-2009, 04:12 PM
QuagmireS2k's Avatar
You are wasting your money if you changing it every 3,000 miles. If you are using a synthetic oil every 6,000 miles is best. Also try using a new oil. Mobil has gone down the drain in the last few years different formulation. The only certain way to know if your oil needs to be changed is for your oil to be analyzed.
Old 02-18-2009, 04:43 PM
r6elmo's Avatar
some cars can last up to 7K between oil changes. This can be because of the larger oil capacity. M3 holds about 7 quarts of oil for a 3L. The FC20 holds a bit over 5 quarts for a 2L.
I intend to change mines every 5K
Old 02-18-2009, 04:44 PM
hariku821's Avatar
If mobile one isnt good any more, what other off the shelf brand would you recommend..
Old 02-18-2009, 04:48 PM
erenyes's Avatar
Amsoil FTW
Quick Reply: How often do you change your oil?
