HOW THE #### DO I REMOVE THESE BOLTS!
Old 06-15-2010 | 05:25 PM
CHEESEFRIES333's Avatar
Default HOW THE #### DO I REMOVE THESE BOLTS!
Im trying to install IZZY brackets but the oem latch on the driver side is bolted on using these crazy looking contraptions and i have no clue how to remove them. Anyone know what to do or at least what they are called so i can remove them? Thanks in advance!
Old 06-15-2010 | 05:27 PM
japhethwar's Avatar
The picture isnt very clear but those look like rivets to me. If they are you have to drill them out. Good luck.
Old 06-15-2010 | 05:39 PM
Incubus's Avatar
Yeah, they weren't intended to be removed.
Go to this site to read up on them. http://www.mcmaster.com/#rivets/=7jsvx1
Old 06-15-2010 | 05:52 PM
Wildncrazy's Avatar
yup those are rivets, but what is an Izzy bracket?
Old 06-15-2010 | 06:16 PM
can i take a dremel tool and slice a line into it and unscrew it with a flathead? FML
Old 06-15-2010 | 06:27 PM
dave2k's Avatar
No, there are no threads on rivets. Like the other reply stated you need to drill them out using a drill slightly bigger than the hole in the middle.
Old 06-15-2010 | 06:29 PM
AZDavid's Avatar
Izzy brackets:
http://izzyscages.wordpress.com/2008/08/01...rdtop-brackets/
How to remove rivets:
http://www.ehow.com/how_4611869_remove-rivets.html
Old 06-15-2010 | 09:57 PM
Blue_S2's Avatar
That's the hardtop latch? Strange all my latches have 2 screws where your rivets are. Even on my soft top. I removed them so they wouldn't make any noise.
Old 06-16-2010 | 04:18 AM
xoz's Avatar
xoz
holy sht somebody replaced the screws with rivets, as per above you'll have to drill them out.
pic below, borrowed from shopman, has replace the screws with allen head bolts..red arrow.
Old 06-16-2010 | 09:43 PM
secondhandloser's Avatar
drill baby drill...
