How do I get these on!
Use a breaker bar or use an impact wrench. You want to "snap" the bolts loose; just pulling is not going to work. Also, be sure to use anti-seize on the bolts next time and torque to the proper specification. Over-tightening the lugnuts can also lead to warping your rotors due to uneven pressure.
I use a big bar with a copper pipe over the end when I have a stuck lug. Then I try to unseize it with a quick jerk to snap it free. If you end up stripping the lug, you need to pound on a smaller socket with a hammer and continue.
