Hotwires Nology Cable
at first i didnt think they would offer wires for a coil-on-plug setup. a little searching showed that they have them for the k20 motor. should work the same.
now as far as good or bad ill let some of the other guys chime in on this.
heres a link to the install procedure for the k20.
hotwire install k20
EDIT: did some reading on the rsx boards and apparently they are not good. they show a power loss and electrical noise.
hotwire install k20
The K20 application is pointless. You remove the stock coils to remote mount them, then run plug wires from the coils to the plugs.
I've seen several bad sets of Nology wires, meanwhile stock NGK wires on hondas that use plug wires last forever.
Considering the stock coils don't have any issues untill you start adding 15+ psi of boost, I wouldn't mess with it.
Moving to S2000 talk, Product inquiry.
