Hot shifter normal?
If its warm outside, metal shifters can get really hot in a parked car.
But even in cold weather, if I drive on the highway, around 20 minutes at 4000rpm, shifter will get slightly warm. I presume it's normal.
Having driven many cars, I do think the S2000 shifter can get warmer than other cars. But I think after awhile you do get a feel for what should be normal temp and what isn't. Since the shifter is directly attached to the transmission, and you sit right next to it I think there is slightly more heat than "normal" cars put off.
if youve got time, i would check out the white plastic clip ring on the shifter dust cover boot. ive had a couple of customer with similar symptoms and i removed it to find the clip ring was cracked/broken, heat from underside was seeping upward.
Stock aluminum knob? That one will get fairly warm after some driving, and f#%@#% burn-your-hand hot after sitting in sunlight for a few hours. This is why the Ti and leather-wrapped knobs are popular.
Former Sponsor
My shift knob never get's warm from just driving of course sun will do it but the cupholder area get's a little bit warm but nothing ever get's even close to hot at all.
