Honda S2200 for MY04 (maybe)
#21
Originally posted by emc2
Ok at the risk of showing my ingorance here, are we talking about using a balanced crank shaft or is "a balance shaft" something completely different?
The shaft itself usually spins in the opposite direction to the engine to give it the counter weight that it needs.
Check out this excellent site for information on the various engine configurations and it will probably explain clearer than i can Autozine Technical School
#25
I've been telling you guys for a good two and a half years now that the next "S" is an S2400 folowed a couple of years later by the S3200 - all inline 4s. When are you guys going to listen??
Oh, and don't forget the move back to chain drive in order to save weight and solve the diff problems.
#26
UL
The point is that an I4 engine 2.0L or smaller doesn't *need* balance shafts. A bigger I4 will have vibrations that are problematic. Mitsubishi used balance shafts on everything. I believe they invented the original 2-shaft system for an I4.
Actually, on an I4, one spins the same direction as the crank and one spins the opposite direction, both spinning at double the crank's speed. The 2 shafts also can be used to minimize the vertical shaking of the engine.
Originally posted by PWE 896
Just in passing, the original Mitsubishi 2 litre Turbo (1984ish) used balancer shafts very effectively and SAAB use the principle to great effect also
Originally posted by UKjasonm The shaft itself usually spins in the opposite direction to the engine to give it the counter weight that it needs.
#27
Originally posted by ddelaros
My brother was talking to a Honda engineers and he said that a S2200 model is in the works.
#30
what about those stories that came out on how the S2000 was suppose to had more HP, but decided against it because they didn't...
