Hit hard bump going thru construction
While traveling thru lovely Tifton, Georgia at 1 a.m. last weekend, the lady and I went thru a construction area that included a rather hard transition to an overpass (probably about a 1-2 inch step up). It came up quick, without warning and, as you can imagine, resulted in a helluva thump and a bit of a bang from the rear. I crawled around a bit underneath looking at everything, thumping on this, tugging on that, and could find no obvious damage. There is no evidence that the sub-frame made contact but there was a definite bang/crack. Car tracks and sounds fine and I don't see any need for an alignment check but I will keep an eye on tire wear and handling. The questions I have are what would be the some of the first things to break in a situation like this. Rim damage, tire failure, other? Was the bang likely just the suspension hitting it's stops? Anyone have a similar experience? I am not losing any sleep over this as I have found no evidence of a problem, but if anyone has suggestions I would appreciate them. Thanks.
tire bubbles.
i spun out my car once ended up jumping a 6 inch curb perpendicularly. i had no damage with suspension. even had the ny inspection and they had it on the lift and there was no damage. no bent wheel no tire damage. car tracks straight.
Better double check with an alignment. I hit a pothole last December and I thought I was fine. After further inspection, found out I had dented one wheel on both the outer and inner rim. Pretty hard to see until you get right up close. Car was also misaligned a tad bit. Not too bad though considering that pothole was pretty bad.
