Higher octane fuel
Old 02-20-2009, 03:17 PM
Jwslick's Avatar
Default Higher octane fuel
Anyone tried a few gallons of racing fuel before in their engines or a fuel with a higher octane than 93?Does this give better performance?Is this bad for the car?
Old 02-20-2009, 03:40 PM
macr88's Avatar
Only if you're getting predetonation (pinging)
Old 02-20-2009, 03:41 PM
negcamber's Avatar
Does nothing unless you can tune. Running too low of an octane will reduce hp though.
s2kswe's Avatar
For example, E85 sits around 105 octane. I used that in my previous turbo car, but the performance will not increase unless you do something about the engine or add pressure to the intake. Generally spoken.
Old 02-20-2009, 03:54 PM
SheDrivesIt's Avatar
As far as E85 goes, the car can't use it at all. It would need to be set up for it.
Old 02-20-2009, 03:56 PM
dparm's Avatar
Performance will suffer. The knock sensor will start fiddling to make the car driveable. Expect a lousy idle, rough running, and probably some CELs.
Not worth it.
Old 02-20-2009, 04:01 PM
CKit's Avatar
Not worth it.
Huh? The OP is asking about higher octane fuel. You're talking about lower octane fuel.
Old 02-20-2009, 04:03 PM
CKit's Avatar
I also think lower octane gas won't have a noticeable impact if you normally cruise and short shift.
I've wondered about running lower octane gas on a road trip where you're just sitting on the cruise control. Probably not enough load to matter....
Old 02-20-2009, 04:15 PM
s2kswe's Avatar
That is correct, thats why I used aem ems, bigger injectors + all the other stuff required. E85 by itself is no benefit whatsoever performance wise.
Old 02-20-2009, 06:39 PM
Saki GT's Avatar
Lower octane fuel than recommended also = lower mpg - its not cost effective in the long run.
Quick Reply: Higher octane fuel
