High Revs? Help URGENT
I was just thinking of buying this S2K recently, but as I was driving it, the revs seemed to be pertinently high, cruising around the 100kmh, 60 mph range around 3.5-4k rpm.
I would just like to know how normal is this (this was in 6th gear) ... or is it meant to be in 5th gear?
Thanks -
Thanks -
Right... which would put 60mph around 3.5k (actually closer to 3.2)
Don't know if this helps you at all, but here are the top speeds through the gears...
1 = 42.5
2 = 65.8
3 = 90
4 = 116
5 = 138.7
6 = 166.05
1 = 42.5
2 = 65.8
3 = 90
4 = 116
5 = 138.7
6 = 166.05
ok, maybe I read the tacho wrongly ... must check again Thanks alot anyway ... btw, what kind of gas you guys got over in the states? The highest we got down under in Aussie is about 98 PULP RON ... the normal Premium ULP is about 95-96 RON ... any comments on whether the higher octane one actually helps?
There are different methods of determining an octane rating. I'm not sure we use the same rating system here in the states. Any international owners care to share what their owner's manual recommends?
