HID Replacement
Old 04-05-2010 | 05:14 PM
Stealth Operator's Avatar
4300K (OEM) = Brightest, but it's also fairly yellowish.
5000K = A balance of more white, less yellow.
6000K = Most acceptable white, anything above is pointless.
I would disconnect the battery for novice non mechanical owners attempting a DIY. Also, you don't require a special tool to remove the "special" screw, as mentioned, a pair of pliers will do the same thing without any problems.
The hardest part is to remove the screw on weather/protection cover, that'd require a fair bit of strength.
When refitting a new HID bulb, secure the bulb down first, then connect the ignitors. Otherwise, you will struggle to get anywhere.
Don't attempt to fit D2R bulbs, it might work, but the beam dispersion is wrong as D2R has an additional reflector in place for non projector headlights. Our cars uses D2S only.
Old 04-06-2010 | 05:39 AM
JLUDE's Avatar
Philips 85122+ is the brightest bulb you can run with our 35 Watt OE ballasts. I swapped my stock bulbs for these and noticed a difference.
Old 05-03-2010 | 04:59 PM
Kyushin's Avatar
Banned
What is the bulb used for highbeam, is a 4000k silverstar bulb good?
Old 05-03-2010 | 06:41 PM
H1 standard halogen type.
Old 05-03-2010 | 06:47 PM
sillyboybmxer's Avatar
stick with philips bulbs,....either stock 85122(stock), 85122+(they dont color shift to a bluer light like the stock bulbs), philips CM(colormatch, 5000k color,..it is basically a bulb developed to have the "colorshift" look already, so people dont have to replace BOTH bulbs when one goes,.....currently what i have) or the philips ultinon 6000k,....which i want to try next since i want a tad more color. so you should try those first.
Old 05-03-2010 | 06:56 PM
[APtwo]'s Avatar
HID high beams aren't good cuz when you're flashing someone it takes a while to heat them up and it's bad for them. I'd keep them stock if I were you.
I'm running 6000K for my low beams right now and it's perfect, and still lights up the road much brighter than most cars on the road.
ltspankme11
11-20-2008 05:29 PM
Gutter
03-25-2007 06:01 PM
8OOORPM
09-22-2006 12:35 AM
e12ic
08-23-2004 08:14 PM
Fed
07-21-2004 03:20 PM
Quick Reply: HID Replacement
