Help Wanted...
Administrator
![](https://www.s2ki.com/forums/images/s2ki/ranks/admin.png)
We have been working hard on S2KI v3.0 for a bit over a month now and we are nearing completion.
The new site is much more focused on content that the current one with loads of new content and a slick to system to manage and organize it.
Anyhow with the new expanded system we are going to need a couple Librarians. The Librarians job would be to help maintain the content in a particular section of the site, just like Moderators moderate forums. All of the maintenance is done via a simple to use web base backend. Good proof reading and organization skills are preferred.
Also, I need a small handful of beta testers for the new site. As you find bugs you will be required to enter them into our new Bug DB. Previous Web QA work is preferred.
Please reply here if you are interested and I will contact you.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
I'd be glad to beta test, especially to make sure everything works OK on MacOS X. I'm a software developer and work with QA and bugbases all day.
If you don't get enough people to help as librarians, I could probably be pressed into that, too.
Ted
Ted
I'd be interested in doing some work for the site. Can you give a little more detail about what the librarian job's duties would be? Amount of work/hours per week, an example of a typical task or something like that?
Administrator
Ultimately the amount of time required would depend on how large of a section you wanted to take on.
I would say no more than 1-5hrs per week.
Post a list of work you require to be done and let the volunteers decide from that list as to how much time can be afforded to the project.
Only a suggestion.
Only a suggestion.
![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
