HELP! NEED DIAGRAM
HELP! NEED DIAGRAM
i have searched and searched but i cannot find one. i need the fuse layout/diagram for a MY00 my radiator fans are not running and i believe the reason my car is over heating! i just got the thermostat replaced thursaday adn then tonight this! HELP ME PLEASE!
I had this problem,,, Check the connector on the thermo switch,, it's at the bottom of the radiator tank, on the drivers side,, Mine had a broken wire,, if yours doesn't,, maybe the switch it's self is bad,, unplug it,, jumper out the 2 wire plug with a wire,, start the car and see if the fan comes on,,, (Might even come on with just the key on run) if the fan runs,, the switch is bad,,, also,, try this,,, start the car,, and turn on the A/C,,, if both fans come on,, all your fuses are good,,
Yeah,,, but jumpering out the switch, will eliminate it,,, if the switch fuse is bad,, they still won't run,, With the A/C on,, if they both run,, kinda narrows it down to the switch circuit,,,,
well my a/c is down currently. compressor failed. i was just gonna check and make sure it wasnt as simple as a fuse. i found a diagram in my owners manual and what it said was the fuse appeared good still so i will just tow her into my mechanic again in the morning. it just really sucks cuz i have i have spent so much on her lately for things.
