HELP how can i tell if i have a 2000 or a 2002 hardtop ?
what is missing out of the 2000 hit that should be in the 2002 kit ? installing soon and seen that the relay socket was empty. where is it ? I seen the 2002 kit cost more why ?
ok...I have a 2002 model that has a defrost switch factory installed...well the hardtop kit I have...has a relay...do I need this relay?..."the socket" for the relay is empty anyway...so wtf?
are you sure this is the 1st year the spa yellow has been in the us ? I was thinking this was the 1st year of the blue.
Spa came out in the US in 2001. Ican't answer your question about what's in the kit you have as I don't have a hardtop (though I wish I did). Talk to the dealer you bought it from and ask them what's up. Long shot I know...
On the book that came with my spa yellow hardtop it says "2000 S2000 hardtop install" Maybe this one shouldn't have come from japan ? does anyone have the book that came with your hardtop. would you look on the back of it and tell me what year it says ?
I just dug my book out, the date on the back also says "2000 /S2000 removable hardtop". I know that they order your hardtop by your VIN#, so I am sure you got the right one. We had ours dealer installed, took them several hours.
Hope this helps
Camille
Hope this helps
Camille
Originally posted by JonasM
I understood that hardtops before 2002 had a VIN plate. If there's no plate anywhere (I don't know where they usually put it) then it's probably a MY2002.
JonasM
JonasM
Originally posted by Jettison
Should the 2002 hardtop have a rear defrost button with it being it uses the one on the dash ?
JonasM
JonasM
