Help! Heard a rattle when I opened my trunk
HI, this morning when I arrived at work, I opened my trunk to get my lunch. I heard what sounded like a large screw rattling to the bottom of the inside of my trunk lid. When I closed my trunk, the lid still rattled. What is this? Has this happened to anyone else?
You could try a magnetic pickup wand and snake it through the trunk lid openings.
What I had to do to get a loose nut out was take off the trunk lid and shake it loose.
Pretty easy to do: Undo the two wire connectors and the wire harness clip, and remove the 4 bolts that connect the lid to the hinges. Beware of scratching the forward corners of the trunk lid; wrap some paper towels around them. Then shake that nut out and reinstall. Probably a good idea to retighten the other nuts too.
