help with center console getting warm
my05 is 2 weeks old and i just broke it in
so i VTECed my baby couple times
but what i noticed was that after vtec the center console got warm
is that normal?
or was i doing something wrong?
Jason
is that normal?
Jason
Originally Posted by dookiewhat,Oct 15 2004, 07:51 AM
is it the tranny that is causing the heat?
The transmission if further up, near where you knees are, so that's why that bit get's warm, and everything back from there is drive shaft, which is why those bits get warm. There's also an exhaust under all that which doesn't help matters. But a lot of cars I've driven has the same 'characteristic'. And, unless it's BURNING hot, there's nothing to worry about. It's a little annoying tho because my sodas get all warm.
since we are on the topic of heat, and also seen that you have a grill. Does that cause the engine area to be warmer too?
I have grille-tech speed holes style grill. And it seems like air cannot flow it as smooth as compared to maybe like a mesh grill. My temp doesn't go up or anything, but i was curious if this is bad...
