headlight clear?
headlight clear?
does anyone here in the bay area have a s2000 with cleared headlight signals?
cause i have to need to must have to clear the nasty orange turn signal light in the headlight assembly.
did you guys do it yourself or did you take it to a shop? and also have you experiecned ay leakage from taking the headlight assembly apart?
You can do it yourself. Use your oven and heat it up but not too long, just enough to have the silicone melt so you can seperate it. Remove the casing. Remove the orange. Put it back in the oven, and heat it up, then stick them together. If it does not seal correctly, go buy some silicone seal from Home Depot.
This is basically the process in a nutshell. It can by much more detailed but it just gives you an idea of what's involved.
jays2000
02-08-2002 03:35 AM
enguyen7292
01-22-2002 04:29 PM
