Headlight bracket
Headlight bracket
i was backed into by a trunk on my driver side and the guys bumper basically hitted my headlight and into my fender a little. I fixed the fender and when I put it back i realized the bracket that holds the headlight and fender and bumper together was broken.
I glued it back on and it stays but now my driver side headlight isnt align and theres a crack at the top of the corner. I was told that I have to buy a new headlight and looking at Honda parts and ebay they are about $400 just for the headlight. Is there any other way to fix this, I can't believe I have to buy a new headlight just because a little piece broke off.
i would just get the new headlight. unless you wanna try to fix it. if the crack is on the plastic then you can easily fix that with some plastic filler or you COULD use some jbweld.
same for the bracket you could use some jbweld instead of the glue to put it back on
The bottom piece sticking out on the lower right. It's some sort of special plastic that even JB weld couldn't hold. I managed to use some other glue and it holds but not straight enough.
