Headlight adjustment
I just put in new bulbs in my S. the beams used to shoot out a good 25 feet and now they only go about 10... is it just a simple of loosening the bolts that hold in the housing to adjust it or is there another way?
There is a different way. Long flat-head screwdriver in an access hole to turn a screw that adjusts the height of the beam.
Though if you're having that much of a difference you might want to double check that you installed the headlights correctly.
The owner's manual describes the adjustment procedure. The owner's manual is available for free online through Honda's Owner Link.
