Hardtop Question..
Hardtop Question..
if you get and S2K and then go out and buy the hard top what becomes of your soft top? do you just put it down and then clip the hardtop over the car or does the soft top just get taken out of the car and the hardtop is intalled? how does this work!!! thanx!
You can do it either way. If you're just looking for looks, the soft top can fold down and after a few parts are installed the hard top can be put on. However, some people look for weight savings and will completely remove the soft top (a little more complicated).
The soft top will be down...but it's a little more complicated than that. The first time seting up your hard top there is some installation involved. After than initial time, it's as simple as taking it on or off.
it would just put pressure on the HT, there are 4 clips, two buy your shoulder on each side, and the regular clips on the windshield pillars.
Why would you try and put the top up with the HT on?????
MAtt
MAtt
Originally posted by Balls
what happens if you do something stupid like try to put the top up while the hardtop is on???
for double layer protection... when it rains REALLY hard....
seriously tho... you wouldn't do it intentionally....
I've never been in a convertible before so answer me this : If you're cruising too fast to raise the top.... and you hit the button anyway.... does it go up? What if you sitting around and you hit the button to raise the top... and half a second later you decide... NO... is there a way to stop it? or reverse it before it completes the cycle?
