Hard Top - Does it really makes difference ?....
Old 09-25-2006 | 07:41 AM
FiLi's Avatar
Default Hard Top - Does it really makes difference ?....
Hi,
Would like to know your opinions about using hard-top in track days. Does it really makes difference ? Or just at high speeds compare to the closed vynil roof ?
Since it
Old 09-25-2006 | 07:43 AM
WalkingDrunken's Avatar
might have better luck putting this under racing and competition.
Old 09-25-2006 | 07:45 AM
LuisC's Avatar
Really, I don
Old 09-25-2006 | 07:51 AM
mikegarrison's Avatar
Test it.
Old 09-25-2006 | 09:32 AM
AssassinJN's Avatar
I think your original thoughts are correct. No increased regidity since it is not load bearing/supportive. Also as far as aerodynamics our cars would not be going fast enough on most tracks to see any difference; you would probably see more of a difference by taping off the gaps around the headlights or in the front bumper than by having a hardtop. Also the slight gain in aerodynamics would probably be offset by the equally ridiculously small weight gain.
That is unless you remove the soft top & motor and replace it with a hard top. Then you will get some weight savings and aerodynamics which may make small differences on long courses.
nicholas316
08-05-2008 04:43 PM
FiLi
10-02-2006 08:06 PM
Filthy Beast
07-03-2006 09:07 AM
Joe04sk
05-17-2005 07:54 PM
gerryk
05-26-2004 06:06 PM
Quick Reply: Hard Top - Does it really makes difference ?....
