Ground Control Coilover Conversion vs. Comptech
I've been looking at springs mostly because I cant afford a full kit, bit I dont want to drop the S very low, maybe just 1/2-3/4 inch most of the time. I ran across the Comptech Adjustable Spring kit and then through searching here found the Ground Control Coilover conversion kit. I read the search results here, but I wanted to know if anyone had anything new add. Both kits seem about the same except the Comptech is about $300 more. The Ground Control kit uses Eibach springs. Any input is greatly appreciated.
Thanx in advance,
Brandon
Thanx in advance,
Brandon
Originally Posted by drifttolga,Jan 30 2007, 01:54 PM
I was driving in my friends s2k. He has Ground controls and Eibach springs . They are softer than Oem and i didnt like them.
You can choose the spring rate these come with. The default kit has really soft rates that will give you this impression. I suggest you pick the correct rates. The setup is excellent if you know what you want.
Wrong answer for who ?
When my friend bought them , there wasnt a choice of different spring rates. So i guess you are a pro , What Spring rate should we pick to make them work better then oem ?
As I understand it, if you dont specify your spring rates, they will default you to a softer setup. You can get ground controls as hard as your spine can handle, so any complaint about spring stiffness on a GC kit is purely the customer's responsibility.
Originally Posted by nearwater4me,Jan 30 2007, 05:33 PM
Are those Ground Control kits reliable?
I've heard bad rumors before, but don't see any complaints here on the forum.
Just wondering.
TIA
Dan
Just wondering.
TIA
Dan
Obviously, I have had exactly zero experience with their S2000 kit, but all their other stuff I have come in contact with has been incredible. On top of that, GC warranties their stuff for EVERYTHING. They dont care if it has been raced/abused/etc... they warranty it.
I am thinking hard about the GC kit for my S, so Im gonna follow this thread closely.
