The great spring question. Eibach, KG/MM, or H&R ?
Old 06-26-2003, 06:12 AM
Brutewes's Avatar
Default The great spring question. Eibach, KG/MM, or H&R ?
Gonna be dropping the S when I get it. Have the Eibach prokit on my civic now, and love it. But I've heard great things about the other 2 brands. So...post your pics with these springs, and state your opinions, please.
Thanks!
Old 06-26-2003, 06:43 AM
SC-SUZUKA's Avatar
H&R springs
Chris C.
Old 06-26-2003, 06:48 AM
Brutewes's Avatar
Wow...aren't those .75 front, .60 rear drop? That looks pretty low for that...very nice. How is the ride?
Old 06-26-2003, 07:08 AM
Banned
GChambers's Avatar
Koni shocks-KG/MM Super Sports.
Ride is better than stock. Turn in is great. Handling is fantastic. The only problem I have had is that I can not get less than -2.0 deg of rear camber with this set up. I have the Konis set on the bottom perch. This gives about 1/2 in of drop and the springs give about .7 in drop.
I think the improvements are mostly because of the Koni shocks though. They are fabulous. I wouldn't do the springs without doing the shocks also.
Old 06-26-2003, 07:21 AM
payyourtoll's Avatar
I have some h&r sports used for 3k miles for sale if anyone wants them (sorry for the pitch)
Old 06-26-2003, 07:45 AM
SC-SUZUKA's Avatar
Chris C.
Old 06-26-2003, 09:33 AM
darkknight1999's Avatar
Eibach Pro kit and I'm very happy with them!
Old 06-26-2003, 09:42 AM
Sleepy's Avatar
Hey darkknight,
You have one of the nicest S' I've seen...
A couple of questions about your setup - (1) Are you running with stock shocks, and (2), how would you compare the ride to stock?
My apologies if you've answered these questions a 1,000 times before...
Thanks!
Old 06-26-2003, 09:44 AM
Thank you kindly. :tips hat:
Yes I do run with stock shocks, and I feel the ride is pretty much the same as stock. The ride is a little stiffer but I feel that its due to the 18's not the springs.
-John
Old 06-26-2003, 12:11 PM
Banned
GChambers's Avatar
Sleepy,
The stock shocks have a fairly stiff compression. This is what affects how the car rides. I don't believe changing springs is going to affect the ride much.
Quick Reply: The great spring question. Eibach, KG/MM, or H&R ?
