Got my NA AP2 S2000 tuned with AEM EMS 1052
I got my car tuned recently at P-Tuning in Manassas, VA with an AEM EMS 1052. Car drives really well, almost like stock. I can definitely feel a big jump in mid-range power (there's a good amount more torque from 2700-4000 rpms). There's not much to gain in peak power, but I was happy with the gains in the mid-range. VTEC engagement was lowered to 5300rpms, and I asked that the redline be raised to 8600rpms.
P-Tuning uses a Dyno Dynamics Load bearing dyno which tends to read much lower than a DynoJet dyno but is much better for tuning. (Details on their dyno: http://www.ptuning.com/html/awd_dyno.cfm)
Only real problems I've had so far is getting the car started (seems to be a problem with everyone who has an AEM EMS), and ocasionally the idle "hangs" at 2000rpms, a blip of the throttle gets it to settle back down at 1000rpms. The car's exhaust also seems to "pop" on part-throttle deceleration -- but I've heard thats also "normal" for cars with an aftermarket exhaust.
My mods are:
- AEM v2 Intake
- Ricks Plus 6 Header
- SuperSprint Exhaust
Dyno Sheets (click picture for more pics and larger resolutions):
I also have an old DynoJet dyno page on there from Fall Colors '05 where I made ~209whp. I think its pretty good that I made ~209 on a Dyno Dynamics dyno.
My mods are:
- AEM v2 Intake
Originally Posted by LegendaryHarry,May 5 2008, 04:03 AM
how much lower does this dyno read than a dyno jet?
I'm not sure those are good comparisons though. The Dyno Dynamics dyno is read on an indoor dyno that has a humongous fan setup that properly estimates wind on the road, while the DynoJet I was using was one of those portable jobs (outdoor dyno) with some little tiny fans. The DynoJet graph also shows I was making over 150 ft-lbs of torque, but the Dyno Dynamics only reads 138.8 ft-lbs.
But, I've heard Dyno Dynamics dynos read lower than Mustang dynos and are as much as 25% lower. The problem is, there's no way to calculate a 100% accurate percentage lower ... Its not a linear scale. So if the DynoJet reads 5% lower @ 2000rpms, it might read 10% lower @ 5000rpms ... if that makes sense?
This is the first non boosted aem load tune I've seen. As far as I'm concerned, that's the only way to tune an S on a dyno. You can really tune the middle ranges.
It makes a big difference on boosted cars too. Tuning the middle is hit and miss on a dynojet. Being able to hold any load speed and tune is the way to go.
fltsfshr
fltsfshr
Originally Posted by Terror,May 5 2008, 09:09 AM
It looks as if you still need to pull VTEC down a bit. Or maybe I'm just seeing things.
Compared to the Toda reflash, I don't have a test pipe so I'm assuming I wouldn't make the same power, or be tuned the same way.
Originally Posted by qbmurderer13,May 4 2008, 11:18 PM
Its so awesome ap2's can make power till 8600. After 8300 ap1s power curve just cliffdives
DynoDynamics reads about 10whp lower than a DynoJet for an NA s2k.
