Got an '06?
Old 03-10-2006 | 04:24 AM
yeliaB's Avatar
Default Got an '06?
hello all,
If you have an '06 and you've installed an aftermarket exhaust, did you have any problems getting it to fit? The reason I ask is that I saw a post from 2QYK4U in the "UTH changes on the 06 S2000, what makes it different from 00-05's" topic that indicated that he had some problems.
Anyway, I thought it would be a good idea to put all the experiences of my fellow '06 owners in one place for future reference...
Thanks!
Ed
Old 03-10-2006 | 04:42 AM
2QYK4U's Avatar
Honda changed the exhaust channel on the MY06 S2000. It is completely straight; PY S2000s must have had a couple of bends in the exhaust channel because the b-pipe itself has two bends in it. So, when I got my Invidia exhaust, one of the bends in the b-pipe conflicted with the straight exhaust channel. I ended up paying $250 to have the b-pipe custom fab'd.
Old 03-10-2006 | 06:55 AM
Wisconsin S2k's Avatar
this is not an under the hood "car problem". please post in the correct forum.
moving to S2000talk...
Old 03-10-2006 | 07:57 AM
dead-bird's Avatar
I could not find any '06 part numbers to check against previous model years, but I some how doubt that there is a difference.
Looking under my '04, the exhaust channel looks straight to me. Not hardly enought real estate under there to do it any other way.
Old 03-10-2006 | 08:12 AM
Nimbus's Avatar
I can also confirm that the exhaust channel is different on the '06 along with some other things in the undercarriage.
As I have suggested in another thread, can someone please post full undercarriage pics of pre-06 vs '06 so we can compare?
Old 03-10-2006 | 08:18 AM
yeliaB's Avatar
[QUOTE=Wisconsin S2k,Mar 10 2006, 10:55 AM]this is not an under the hood "car problem".
Old 03-11-2006 | 05:23 AM
yeliaB's Avatar
So, is 2QYK4U is the only '06 owner to try an aftermarket exhaust so far? I think dead-bird might be on to something about checking part numbers; I have to drop by the dealers for one of those damn phillips screw plastic clips, so I'll ask the parts guy for the numbers for the '04, '05, and '06 B-pipes and see whether Honda thinks there was a change (and when it happened). I'll let you know what I find out...
Thanks for the good information!
Ed
Old 03-11-2006 | 05:34 AM
2QYK4U's Avatar
Ed
That's a good idea. I have the new Helm's manual, which covers MY00-06, and they show the same picture for the MY04-06 exhaust.
Old 03-11-2006 | 09:34 AM
yeliaB's Avatar
[QUOTE=2QYK4U,Mar 11 2006, 09:34 AM]That's a good idea.
Old 03-11-2006 | 10:51 AM
yeliaB's Avatar
Well, I talked to the counter guy at my local dealer's parts department. He checked his eight *feet* of shelf space dedicated to clips (!) for the clip I busted putting the alarm's hood switch on my '06, and found that the little plastic phillips-head screw in clip is special to the S2000, and would have to be ordered for $4 a pop thank you very much.
Anyway, I then asked the guy to check out the part numbers for the B-pipe in the '06 and the '05. They're different. He said he really had no way of knowing why the two years had a different part number for this part and, unlike an autoparts store, they don't have any cross-reference information, so there's no way of determining compatibility between any two model years -- either the part numbers match (and are compatible), or they don't.
So, I guess it's gonna take someone getting an '05 up on a lift and taking pictures, and someone else doing the same for an '06. I'm certainly game to do my part in solving this mystery -- does anyone in my area have access to a lift so I can take some pictures?
Ed
Quick Reply: Got an '06?
