Gears
#91
Originally Posted by mikegarrison,Aug 23 2005, 11:28 PM
That overstates the advantage, because some of the time the car with stock gears will be in a lower gear. The car with the 4.57 will never be in a lower gear. In all cases, when the car with the 4.10 is in a lower gear, it actually has the torque advantage.
So you have to subtract the time when the 4:10 has the torque advantage from the time when the 4.57 has the torque advantage. When you do that, the differences close up quite a bit, and you get only a small change.
Hmm... I guess looking at it, 70% of the time is good, but isn't THAT GREAT. If, during those windows, the cars come out even, it's a worthwhile investment. If the stock car really does have the advantage, even after taking into consideration the gearing advantage, it's not so great.
Edit: Ooh cool, my numbers match the ones on the graph, and it looks like the stock car does indeed have the advantage 30% of the time.
#93
Originally Posted by CrazyPhuD,Aug 24 2005, 12:47 AM
ok so I as asked to make another one of these graphs showing effective torque as a function of MPH. THe results are interesting and not quite as dramatic as I expected.
that said if you compare the two curves you will see that the 4.57 geared car has a greater torque advantage on average than the MY00-03 without gears(ignoring about 150 which is drag limited anyway)
The point I was trying to make here all along is that there will be intervals in which the 4.57s are not an improvement.
#94
if by the time I'm at 105mph shifting to 5th, and the other car is only at 95mph (since I accelerated faster), I'm already ahead of the game. while he may slow or sustain my accelerating advantage, it's short lived, because soon enough he finds himself having to upshift, and I once again have an advantage that is probaly double what he just had.
again, graph it out and you'll see the whole picture. whether .4 seconds to say 100mph is "small change" to you is your deal.
however, I find it interesting that while you said Force is unaffected by gearing, at the same time you are conceding that gears can give you a small acceleration advantage. however, if that's true, taking the equation F=ma, since you concede a goes up slightly, this means F also went up since mass is constant. yet gearing doesn't affect F? interesting.....
#96
Originally Posted by jasonw,Aug 24 2005, 01:58 AM
Good work. That is very much in line with what I expected. Do you have a formula or is that based on existing data points?
#97
also another article how gearing increases acceleration.
http://www.findarticles.com/p/articles/mi_...308/ai_n9287022
#98
Originally Posted by mikegarrison,Aug 24 2005, 01:30 AM
Really? Disengage the clutch and remove the engine from the system. Those gears are still connected to the drive line, only the engine is not.
Now how much force do you have pushing the car forward?
now how much force do you have pushing the car forward?
#100
Originally Posted by jasonw,Aug 24 2005, 01:54 AM
HP = TQ*RPM/5252
acceleration is calculated using mass and force. force does NOT use horsepower anywhere in the equation. as i said, hp is irrelevant in determining a car's acceleration.
and, I said I did not know how to graph it out in a timely manner with an EXCEL spreadsheet. must I be so damn literal with you? sheesh. give me a pencil, paper, and ruler, and i can plot it out.
