Gas gauge
Old 11-14-2000 | 11:14 AM
Zero-60in5's Avatar
I've put about 3 grand on my red stook and have noticed that each morning, when I get in my car that the gas gauge is 2 to 3 ticks down from where it was when I parked it the night before. I chalk that up to the fact that the gas gets more dense as it gets colder during the night. The problem is that if I'm 4 ticks from empty, when I get in in the morning, the gas light is on and it makes me nervous. I'd hate to run out of gas in the stook. Yeah, yeah, I can just hear some of you thinking, "Then keep the tank half full." I have this funny thing about wasting my time pulling into gas stations more than I have to, especially since I could be spending that time behind the wheel instead of pumping the gas.
Anyone else beside me notice the gas gauge difference when the get into the stook cold?
Old 11-14-2000 | 11:18 AM
Hootsama's Avatar
All I know is that my StooK drinks more than I do (and, believe me, I drink a lot!). Granted I use Vtec as it was intended, so the revs stay fairly high most of the time, but it's not like I'm beating on the car, or red-lining it with every shift. The other day, I filled it up with 93 and reset the trip odometer (as I do after each fill-up). By the time I had 6 miles on the odo, I had already lost a "tick" on the gauge. By 70 miles, even more ticks gone...
The damn thing gulps the fuel down... I think I'm lucky to get 17-18 MPG around town.
Old 11-14-2000 | 11:20 AM
VA S2K's Avatar
Same thing here, except my house sits on a hill and the driveway is sloped too which is where I park the car quite a bit so the gas gauge reads all over the place. I just wait 'til I get going and then after a few miles take the reading and decide whether to gas up or not
Dented S2K's Avatar
I think its because as you drive it sloshes around and the level appears to be higher...
Obviously, when it hasn't been driven its not sloshing around.
I get a similar effect when I'm on a steep incline or decline, the gauge will go up or down.
Old 11-14-2000 | 11:22 AM
krazik's Avatar
Administrator
Your gas milage is directly proportional to the amount of time you spend above 6kprms!
I got 9.5 mpg on sunday at the track
Old 11-14-2000 | 11:25 AM
Hootsama's Avatar
Well, it could be worse... I could have a guzzling v-8 stanger or LS-1. Then I would have MAJOR gas woes to go along with my rattles and flimsy construction.
Old 11-14-2000 | 11:27 AM
S2WOOOW's Avatar
The density change will not be anywhere close to being noticable on a gas gauge. On a thread somewhere it said that the gas gauge is calibrated every time the car is turned on. So if it is started once on a slope, and then driven to level ground, it would read different if started on level ground. I've noticed I can get 1 tick difference if I start the car in the garage vs starting the car in the driveway.
Old 11-14-2000 | 11:32 AM
Pinky's Avatar
[QUOTE]Originally posted by krazik-s2k:
[B]Your gas milage is directly proportional to the amount of time you spend above 6kprms!
Old 11-14-2000 | 11:36 AM
krazik's Avatar
Administrator
[QUOTE]Originally posted by Pinky:
[B] Now that is the worst gas milage I have ever heard from this car!
Old 11-14-2000 | 11:50 AM
Don H's Avatar
The gas gauge does seem to be a little sensitive and erratic at times. Right after I first got my S2K, probably less than 1k miles, my gauge went from 4 bars to no bars in a matter of 10 to 20 miles. It really freaked me out. I quickly found a station to fill up and discovered it was no where near being empty. Another time, I ran her on no bars for over 50 miles before gasing up. It has since settled down and pretty much reflects what's left in the tank.
Quick Reply: Gas gauge
