Gaining Horsepower other than S/C or turbo?
Old 06-10-2003, 07:57 PM
FormulaRedS2k's Avatar
Default Gaining Horsepower other than S/C or turbo?
Ok my question is pretty simple. I'd like to gain some extra horse power but I dont want to spend 3,000 on a super charger or on a turbo kit. What can be done. I know that exhaust does absolutely nothing, and intake is probably the same. What does do somthing? Let me know what kind of upgrades I need to gain some power. Thanks
No NOS either.
Old 06-10-2003, 08:02 PM
Ace10's Avatar
defien "some" extra hp.
getting faster isn't cheap.
also... $5K to $6K for a installed FI system.
best of luck to you.
Old 06-10-2003, 08:19 PM
Quick2K's Avatar
This engine responds very slightly to breathing mods, IE Intake/ headers/ exhaust. Depending on your engine, and a lot of other factors, like how well the parts work together, you could see anywhere from 5-15 HP gain at the peak with those mods. They will, however, give you more midrange if you choose the right combination of pieces. Cams will give you a nice boost, but driveability on a day to day basis might suffer as well as long term reliability-and say goodbye to your warranty.
A full N/A buildup will certainly affect driveability; Higher compression pistons, stronger, lighter rods, a higher redline, a stand alone fuel and engine management system coupled with cams, the breathing mods, and significant changes to the valvetrain will bump HP by a lot, and changes the powerband too. then again, for such a project you're looking at $10-15,000.
If you want more horsepower cheaply, you got the wrong car. My suggestion is to install the 4.44 gear set and simply put the horsepower you already have to better use. Good luck.
Quick2K
Old 06-10-2003, 08:29 PM
xviper's Avatar
If you don't plan on driving extended trips on the highway, might even consider 4.77's.
OR, you can spend a couple hundred bucks for a trailer hitch, give it to someone you know with a Dodge Viper, hook yourself up and go where he goes.
Old 06-10-2003, 09:11 PM
Sounds like I thought it would sound. If im going to spend 10 grand on all that stuff why not just super charge it. Im used to turbo cars with bolt on stuff that will boost up over 100 horse easily. Guess I gotta get used to it. I'd rather have rims.
Old 06-10-2003, 09:16 PM
Intrepid175's Avatar
4.77?? I've not heard of that one. Just how low can you go on the rear end ratios anyway with the S2k?
Drive Safe,
Steve R.
Old 06-10-2003, 09:26 PM
xviper's Avatar
[QUOTE]Originally posted by Intrepid175
[B]
4.77??
Old 06-10-2003, 10:40 PM
S2020's Avatar
If you loose some weight it's the same as gaining HP.
I think the spare tire and jack can go. Easy, cheap ($0), and reversible. (but be prepared to be flat bedded if you have a flat)
Drive around in less than 1/2 full tank.
Old 06-11-2003, 02:48 AM
S2000_Europe's Avatar
Well you can get the
4:44 gears, $ 850
toda header $1150
Toda Cams Spec 1 $1300
Used Exhaust $ 400
Total $3700
And you will feel the difference
Old 06-11-2003, 03:06 AM
Ws2000R's Avatar
[QUOTE]Originally posted by S2000_Europe
[B]Well you can get the
Quick Reply: Gaining Horsepower other than S/C or turbo?
