Fuel level affecting performance?
Is it normal for the amount of fuel you have in your tank to affect acceleration? I've noticed that it greatly affects mine. Even without regard to fuel level, my car seems fast some times and slow sometimes.
2002 with only an OEM lip and OEM wing, both which would have no effect.
Originally Posted by nightcrawler7188,Mar 13 2006, 09:57 AM
I mean it's faster with more gas
Yess definately less weight and better exceleration with less gas. Say 3-4bars as oppose to full tank. A 5gallon tank of water is 50ish lbs. My S holds 11-12 gallons....go figure.
"hiper" you prolly running on fumes thats why. or using 87 grade?
the butt dyno lies. you're perceiving a change that isn't really there. the weather will really be the only thing that will affect your day to day driving.
There was a thread a while back with some members posting the same thing. Some theorized it had something to do with how much fuel is readily available when called upon by the throttle. I suppose that would depend on how low it truly is?
