frt driver's side fender removal??
hey guys
have the esm but for the life of me i can't find the frt fender removal instructions
is there detailed instructions??
Thanks
Bass
Thanks
Bass
I had to pretty much take off the frt drivers side fender a couple of days ago to tighten up my drivers side door (long story). Pretty much easy to just wing it, thats what I did. Nothing but bolts under the hood, inside the drivers door where the hinges are, under the side of the car, 1 bolt that connects the bumper and fender together in the wheel well and the fender well tabs, also remove side corner marker. I only had to have the side that is beside the door loose so I could get my socket wrench in there to tighten what needed to be tightened so I didnt completely remove the whole panel.
OH ALSO! Before you remove the fender!!!! Make sure you make lines (pen or pencil) where the bolts are from the panel to where they bolt for positioning, otherwise aligning the panel will be a MAJOR PAIN!!
hyperpm
06-05-2010 09:00 PM
