which front sway bar would you recommend?
Old 12-15-2006 | 03:17 AM
kfdon's Avatar
Default which front sway bar would you recommend?
i've been looking around for a good front sway bar
and i come arross the
Competition Front Adjustable Swaybar which is quite $$ but i heard their quite good.
and if i plan on getting this one anyone got a place where i can get it cheaper?
any other recommendations?
use for .. daily driving,autoX,track.
thanks
Old 12-15-2006 | 07:25 AM
gomarlins3's Avatar
Comptech front adjustable for me. Had if for 4 1/2 years with no problems. Buy the best and you won't regret it.
Sometimes they come up used on eBay, but rarely.
Old 12-15-2006 | 11:22 AM
thetz99's Avatar
The Comptech adjustables best feature is that it replaces the pressed OEM holddown clamps with 2 huge billet holddowns which allow you to fit the beefy adjustable bar with proper clearance
I think it is the only one to do this holddown replacement.
Old 12-15-2006 | 11:25 AM
milkbubble's Avatar
I got a Comptech from my best friend for free when he turned in his leased S2k. It changed the whole car and im set in the mid rate of adjustment. I will experiement with the other settings next auto X season. I cant comment on the other bars though.
Old 12-15-2006 | 12:36 PM
Invision's Avatar
the swift stabilizer bar is good
Old 12-15-2006 | 02:49 PM
zbrewha863's Avatar
If you go into the Racing subform, there's a sticky at the top for a huge post with a bunch of info titled something like "what you need to start auto-x'ing" -- anyway, in there they have some info on three adjustable front sway bars if you're after an adjustable one. I have heard things about some of the non-adjustable sway bars as well, namely Swift and Beatrush.
Old 12-15-2006 | 04:29 PM
AJ PwR's Avatar
Just replace your rear to the 25.4mm. My time attack results has proven the setup works
Old 12-15-2006 | 06:59 PM
gomarlins3's Avatar
Be ready for some oversteer with a bigger rear sway bar.
Old 12-15-2006 | 08:17 PM
kfdon's Avatar
yea i also need to take out my tower bar to go back down to A stock for autoX, unless i have crazy mods to hold me in BSP, so i wont need to take stuff off for autoX and put more in for track
wont the 25.4 rear sway bar give me too much oversteer? in agressive turning in autoX? your track set up i'm also interested but won't i need to get alot more suspension set up than just bars?
Old 12-15-2006 | 08:41 PM
AlX Boi's Avatar
Would sway bars make the ride more rough for DD?
What are some pros and cons? I'd like to pick up a few Cusco parts.
Quick Reply: which front sway bar would you recommend?
