front jacking points
i noticed that there are 2 front jacking points behind the front wheel. which one is the correct one to use? i used the one closest to the front wheel, and just now i've read that u should be using the 2nd one from the front wheel. did i damage anything? i lookedi n the owner's manual and it is very hard to tell which is the right one. thanks.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Their are jacking point behind the front wheels. Theirs a spot that has more metal than under the fender, look for that spot or else you could risk damage to the fender. Its about 6'' behind the front wheel, in between the door jam and the half way towards to fender.
The correct jack point is the 2nd one, closer to the rear of the car. The front one is a fake, don't use it.. you probably bent the flange, but shouldn't have done any damage.
