Friendly Reminder: Check your oil level!!!
#21
Originally posted by RazorV3
i dont like checking the oil at the gas station because the engine is still warm and can give deceptive readings. i usually let the car sit overnight and check it first thing in the morning(lets all the oil drain to the bottom of the oil pan).
#22
20-30 minutes later I checked and the level was on "F".
So I always check (and add oil) when the car is cold now.
#24
One factor to consider is that the oil swells when hot, so letting it drip down too long when it is hot and then checking can give you a false reading (high).
Yet, the only car I have ever owned that has two index points on the engine oil is this high performance engine: Subaru 2.5L.
Go figure.
So when checking hot, do it at about 5 minutes, or approximately at the end of a fuel fillup and payment.
Everyone knows that auto tranny fluid has two index points for checking level - "cool" and "warm/hot". The reason must be that in many cases, the level can only be properly checked when the car is running, whereas you cannot accurately check engine oil level when it is running.
Go figure.
#26
I've had MGAs most of my life, so routinely checking the oil is standard procedure.... although it was unexpected with a new Japanese car! I found my car using one quart every 1,700 miles and this continued until I hit about 10,000 miles on the car, when it started to tapper off.
Tip: I check my oil after every fill up of the gas tank; however, I do not do it at the station, nor do I do it when the engine is warm unless I'm traveling. I made up a card reminding me to check the oil and I keep it in the small storage area behind the radio door. When I drive into the garage after getting gas, I reach in and pull out the card and place it by the shifter. The following day when I jump in, I'm reminded. That's when I check it - in a level garage with good lighting and when the oil cooled down and settled to give an accurate reading.
Tip: If you've allowed the oil to drop lower than one quart I would recommend getting a complete oil change as soon as possible. Driving with 40% of the oil gone can do serious damage quickly to the remaining 60%. Get it out ASAP.
Tip: When checking be sure you fully insert the dip stick back into the block. There have been numerous reports of people failing to do so and the dip stick popping up and spreading oil throughout the engine compartment.
Tip: When reading the dip stick read both sides, and go by the lowest reading.
Tip: If adding oil be sure the cap is retightened fully, as again there have been numerous reports of the caps vibrating off and large amounts of lost oil resulting.
Finally, there is Variation in Engines: Some S2000 engines will consume more oil than others depending on the tolerances inside the engine. Don't worry about it, just get in the habit of routinely checking.
